Community Member
CUCM upgrade 8.5 to 8.6 failed on Subscriber.
CUCM upgrade from 8.5 to 8.6 fails on VMWare.
We have already applied patch ciscocm.refresh_upgrade_v1.1.cop.sgn, and restarted the cluster.
Publisher is upgraded from 8.5 to 8.6. But subscriber upgrade is failed two times.
Is there any other posibilites, why upgrade from 8.5 to 8.6 failing ?
Here I have attached the logs I got during upgrade, two failed upgrade log files attached.
Current version of CUCM-SUB is 8.5.1.10000-26 (running on VMWare)
upgrading to 8.6.2.20000-2
After approx. 90 minutes during upgrade it endup with error.
admin:show version ac
admin:show version active
Active Master Version: 8.5.1.10000-26
Active Version Installed Software Options:
admin:show version in
admin:show version inactive
No Inactive side available
Pls. advice.
Rgds
Rajesh
1 REPLY
Hall of Fame Super Red
Hi Rajesh,
I would recommend opening a TAC case here. There are a number
of bugs that may be hitting you here
Here's an example;
https://supportforums.cisco.com/message/3455576#3455576
Cheers!
Rob
382
