CUCM upgrade 9.0 to 9.1 fails on Subscribers
Hi All,
I am in the process of upgrading CUCM ver 9.0.0.99101-22 to 9.1.1.20000-5(On UCS C series-VMwaremachine)
There is no issue in upgrade the version in the publisher, but unable to upgrade subscribers.Tried following steps.
  • Activated 9.1.1 version on Publisher first, restarted.
  • Restarted DB replication on all nodes.
  • DB replication state is good, But count 603 in Pub & 604 in all Sub's.
  • Getting following Unknown error.
Attached Installation log while failing........
Alagu
Everyone's tags (1)
VIP Purple
Hi Alagu,
After seeing the logs, it seems there is a version mismatch
ontape_backup pulled from the pub is of a different version than running on this subscriber |<:DEBUG>
08/30/2013 21:21:21 component_install|(CAPTURE) |<:DEBUG>
08/30/2013 21:21:21 component_install|(CAPTURE) Fri Aug 30 21:21:21 2013 dbllib.getDataFromPub  DEBUG:  please reupgrade the pub, this will regenerate the correct backup of the version that subscriber is being upgraded to |<:DEBUG>
08/30/2013 21:21:21 component_install|(CAPTURE) Fri Aug 30 21:21:21 2013 dbllib.getDataFromPub  DEBUG:  Install is going to fail now |<:DEBUG>
regds,
aman
Cisco suggested not to install CUCM 9.0 versions, it's for developers.
Also I have identified that Licensed MAC will not be generated for 9.0 versions.
Got bootable 9.1.2(Direct installation) & resolved the issue.
ALAGU
VIP Purple
Hi Alagu,
Thanks for update.
Did u get any supporting documentation?if yes,please share.
regds,
aman
356
