CUCM Upgrade failure.
haouaswajih
Level 3
Level 3
Dear Voipers,
We are upgrading our callmanager 3 nodes cluster from version 6.0.1.2000-3 to version
6.1.2.1000-13.
We have successfully upgraded the publisher and one of the subscribers.
The issue is when trying to upgrade the last subscriber using the OS Administration
interface>Software Upgrades>Install/Upgrade and after specifying the local source we
have an error message : An unknown error occured while accessing the upgrade file.
Please note the following :
- We are using the same DVD used to upgrade the first 2 nodes
- We have tried using Remote Location (SFTP) and we got the same error
- We have rebooted the server and tried again using DVD then SFTP but we got the same
error.
Thanks in advance.
shane.orr
Level 4
Level 4
Did you ever figure this out, I am having a similar issue..?
I had a similar problem a while ago and what I had to do was execute the upgrade from the command line.  It was the only way to get the upgrade to work.  I also so inconsistency on when I had to follow this method and when the GUI worked fine.  I tested this on multiple systems and multi-node clusters.  The issue wasn't common, but I hit it more than once.
I documented my procedure in the following URL.  Hopefully it helps you.
http://www.netcraftsmen.net/resources/blogs/cisco-uc-application-upgrade---the-cli-method.html
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
I will work on it, regardless GREAT INFO!!
