CUCM Upgrade from 5.1.2.3132-1
Hi everybody,
I am facing an upgrade from CUCM 5.1 with the System Version 5.1.2.3132-1 to 7.1(5)
I can't find this particular release in the compatibility matrix:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp43011
so I am a little bit afraid, cause it might be an engineering special or something like this.
I can't find anything after 5.1(2b), which is 5.1.2.3000
I think I have to go through 5.1(3f), which is the "newest" version supporting upgrades from 5.1.2 and then go directly to 7.1(5).
Any hints are welcome.
Kind regards
Christian
1 REPLY
Hall of Fame Super Red
Re: CUCM Upgrade from 5.1.2.3132-1
Hi Christian,
The version you are running is in fact an ES (engineering special) as you nicely
noted You should be fine to move forward with your suggested upgrade path.
From the doc you linked;
Notes about Engineering Specials (ESs), Service Updates (SUs), and Windows Service Release (SR) Upgrades
If you run a Linux or Windows Engineering Special (ES), a Service Update (SU), or a Windows Service Release (SR) for any version listed in the "Direct upgrade" tables in the following Supported Cisco Unified Communications Manager Upgrades, you can also upgrade to the target version for that section.
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
160
