Community Member
cucm upgrade from 7.0.2 to 9.1
I have an Ip telephony setup with CUCM (Publisher and subscriber) version running on MCS server 7825I3.We would like to upgarde to CUCM 9.1 using the same hardware platform.The hardware details as follows.Both publisher and subscriber running the MCS 7825I3 servers.
1. Does this hardware is suffifcient for the cucm 9.1.?
2.what are the upgradtion steps have to follow from 7.0.2 to 9.1? about the licensing part?
Thanks in advance
Nithin Louis.
HW Platform       : 7825I3
Processors        : 1
Type              : Intel(R) Core(TM)2 Duo CPU     E6400  @ 2.13GHz
CPU Speed         : 2130
Memory            : 4096 MBytes
Object ID         :
OS Version        : UCOS
Serial Number     : xxxxxx
RAID Version      :
RAID Firmware Version:
RAID BIOS Version:  6.0e.00.00
BIOS Information  :
Vendor: IBM
Version: IBM BIOS Version 1.38-[G9E138AUS-1.38]-
Release Date: 01/07/2008
RAID Details      :
LSI Logic IR Configuration Utility 2.00.15
Background command progress status for controller 0...
IR Volume 1
  Volume ID
   : 5
  Current operation
  : None
  Volume status
   : Enabled
  Volume state
   : Optimal
  Physical disk I/Os                      : Not quiesced
1 read the hw compatibility matrix, its onc CCO and has been posted at CSC thousands of times
2 read the upgrade guide for 9.x release youre going, along with the RNs
3 youll need to reach the licensing team
If youre a partner, go to the partner community, and read the drive to 9 information
if this helps, please rate
Hi Nithin,
As suggsted by Mr. Jaime, u can refer the guides.
You can use the existing Harwdare for upgradation to Call manager
secondly, u can upgrade from 7.0.2 to Restricted 7.1(5b)SU6a and then, to Unrestricted version of, u need to install COP file ciscocm.refresh_upgrade_v1.2.cop.sgn
Lastly for licenses u can refer the discussion.
The only item not listed above is the hard drive size, which has to be 160+ GB for 9.x, otherwise as Aman said you're server meets the requirements for upgrading.
