Community Member
CUCM upgrade from 7.0 to 9.0
Kindly can i upgrade directly from CUCM 7.0 to 9.0 ?
If not , What is the required sequence of CUCM versions to reach to v 9.0 ?
Everyone's tags (1)
Review the SW compatibility matrix for that kind of questions
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Unfortunately thats not possible. You will have to jump to a 7.1 version before upgrading to 9.1. Please refer the compatibility guide here to come up with a plan. Keep in mind, look out for the minor versions since certain 7.0 minor version require you to jump to another intermediate 7.0 minor version before moving forward.
Please rate useful posts.
Community Member
according to the document , to upgrade to 9.0(1) directly, i should do this from 7.1(3)
and i can upgrade to 7.1(3) directly from 7.0(2)
and upgrading to  7.0(2) directly from 7.0(1)
is this right ??
Purple
Hi ,
you are correct.
to upgrade to UNRST 9.1(1a) , u require minmum 7.1(3) and also, install COP  file ciscocm.allow_upgrades_to_unrestricted.cop.sgn
from 7.0(1) , u need to upgrade to 7.0(2) , then, finally to 7.1.3.10000-11 [7.1(3)]
regds,
aman
Purple
Hi Mohamed,
You need to mention the exact CUCM versions.
You can refer the software compatibility matrix for upgradation.
regds,
aman
182
