CUCM upgrade from 7.1(5) to 8.x
Could I upgrade from 7.1(5) to 8.x?
I couldn't make clear by CUCM software compatibility Matrix.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html
Table 4
regards,
Yoichi/Cisco-Japan PSS
Everyone's tags (2)
VIP Super Bronze
Re: CUCM upgrade from 7.1(5) to 8.x
No; 7.1(5) was tested and released after both 8.0(1) and 8.0(2). You will need to wait for a subsiquant 8.0 release to perform this upgrade.
This will be indicated in Table 4 because 7.1(5) will then be listed as a Direct Upgrade in the table for that release. Sorry to hear this wasn't clear.
Please remember to rate helpful responses and identify helpful or
Red
Cisco builds different "tracks" (or "trains") of software in parallel.
Maybe not a good analogy, but think CUCM 7.x is "Office 2007" and CUCM 8.x is "Office 2010".
CUCM 7.1.5 is like "the latest service pack for Office 2007".  CUCM 8.0.1 is the very first version of "Office 2010".
There's no need to "upgrade" CUCM 7.x to 8.x unless you want the "new features".  Just like there's no point to upgrade Office 2007 SP2 to Office 2010 unless you want the "new features".
Hope this helps!
Michael
http://htluo.blogspot.com
You will be able to upgrade but not until 8.5(1) ,which a lot of people is expecting for Windows 7 compatibility, is finally released. Q4FY10 is the FCS for this release.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Can any one help me on how to upgrade the CUCM 7.1.5 to 8.5 in one HOP? many documents of Cisco creating confusion, provide me the correct path for the same.
MSR
You can upgrade in one hop to 8.5 or 8.6.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp349290
I know this for sure, because 7.1.5 is the only version with DMA... So if you have a 4.x version, you go to 7.1.5 with DMA and then you're going to 8.5 or 8.6.
Steffen
Hi Steffen,
Thanks for your response, my CUCM is 7.1.5 and i would like to upgrade this to 8.5, if you dont mind can you provide me the related path to download the software and upgradation procedure.
MSR
Here is the install and upgrade guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_5_1/install/cmins851.html
And the link to the software:
http://www.cisco.com/cisco/software/type.html?mdfid=283423434&catid=278875240
You need a CCO login and a valid ESW (service contract) to download.
Cheers
Steffen
5713
