CUCM upgrade from 9.1.1 to 9.1.2 is getting failed during installation
Hi All,
Need to upgrade CUCM from 9.1.1 to 9.1.2 (unrestricted)
File getting downloaded correctly , verified MD5sum, its correct
While installing the file on CUCM publisher, installation getting failed saying "Error Encountered: Could not upgrade the file"
Kindly suggest
You'll need to review the
You'll need to review the logs to find the exact cause.
java
if this helps, please rate
www.cisco.com/go/pdi
07/25/2014 02:58:51 upgrade
07/25/2014 02:58:51 upgrade_install.sh|File:/usr/local/bin/base_scripts/upgrade_install.sh:604, Function: main(), Upgrade Failed -- (1)|<LVL::Error>
07/25/2014 02:58:51 upgrade_install.sh|Parse argument status=upgrade.stage.error|<LVL::Debug>
07/25/2014 02:58:51 upgrade_install.sh|_set_upgrade_status_attribute: status set to upgrade.stage.error|<LVL::Debug>
07/25/2014 02:58:51 upgrade_install.sh|is_upgrade_lock_available: Upgrade lock is not available.|<LVL::Debug>
07/25/2014 02:58:51 upgrade_install.sh|is_upgrade_in_progress: Already locked by this process (pid: 3652).|<LVL::Debug>
07/25/2014 02:58:51 upgrade_install.sh|release_upgrade_lock: Releasing lock (pid: 3652)|<LVL::Debug>
That part is just telling you
That part is just telling you that the upgrade process failed. Look a bit higher (earlier) in the logs for the cause.
I,
I,
i'm facing the same problem.
Did you manage to resolve the problem ?
how?
thks.
Nuno
Silly question.  You said
Silly question.  You said "Need to upgrade CUCM from 9.1.1 to 9.1.2 (unrestricted)".  Are you going from a restricted version to an unrestricted?  I assume you are in a country that requires the unrestricted version?
468
