CUCM upgrade fron ver 7.x to 9.x
Hi All,
Please let me the the step by step process to upgrade cucm 7.x to 9.x
Thanks !
Hi,  It depends on what
It depends on what version you have and what version you want to go. For example, if running 7.1.5 you can use the jump upgrade procedure to 9.1.2. Please refer to the document below for a more detailed explanation:
https://communities.cisco.com/docs/DOC-35653
https://communities.cisco.com/docs/DOC-35481
Tere.
Regards, Tere. If you find this post helpful, please rate! :)
Re: Hi,  It depends on what
Please I have to upgrade from 7.0.2 to 7.1.5 at leas for then using PCD a get to 11.5 version. Could you please help me with the procedure and .iso or .cop files needed for this task?
I'd appreciate a lot.
Regards.
79
