CUCM Upgrade
hello
i am hoping to get the thoughs of some of the people on this fourm about upgrading from CUCM 5.x to 7.x
has anyone seen upgrading as a stable approach or would i be better of just doing a fresh install?
thie deployment consists of about 250 users and would be on a MCS-7825-H2-UC1
Re: CUCM Upgrade
You cannot use that server
Cisco MCS 7825-H2-UC1
SUPPORTED APPLICATIONS
The Cisco MCS  7825-H2-UC1 supports Cisco Unity Connection.
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/product_data_sheet0900aecd804566fd.html
You need a supported platform
Supported Servers for Cisco Unified  Communications Manager Releases
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Re: CUCM Upgrade
oops i post the wrong part number MCS7825H2-K9-CMA2 is our current CUCM server hardware
160
