CUCM upgrade
Need some advise i am going to upgrade pub and 3 subs from cucm 6.1 to 6.5 can i install the upgrade in the inactive partition on each server or do i have to do the publisher reboot and than do the 3 subs the same way??????
1 REPLY
Hall of Fame Super Red
Re: CUCM upgrade
Hi there,
The "inactive partition" method for the CUCM upgrade process is the desired
route
The new vesrion is built on the inactive partition and just sits there
until instructed to switch versions. here is an example from the 6.x SRND
Guide;
A cluster can be upgraded to Unified CM 6.x without impacting the services. Two different versions (releases) of Unified CM may be on the same server, one in the active partition and the other in the inactive partition. All services and devices use the Unified CM version in the active partition for all Unified CM functionality. During the upgrade process, the cluster operations continue using its current release of Unified CM in the active partition, while the upgrade version gets installed in the inactive partition. Once the upgrade process is completed, the servers can be rebooted to switch the inactive partition to the active partition, thus running the new version of Unified CM.
Upgrading from Unified CM 6.x to Unified CM 6.x
The 1:1 redundancy scheme enables you to upgrade the cluster using the following method:
Step 1 Install the new version of Unified CM on the publisher. Do not reboot.
Step 2 Install the new version of Unified CM on all subscribers simultaneously. Do not reboot.
Step 3 Reboot only the publisher. Switch to the new version of Unified CM and allow some time for the database to initialize.
Step 4 Reboot the TFTP server(s) one at a time. Switch to the new version of Unified CM and wait for the configuration files to be rebuilt before upgrading any further servers in the cluster.
Step 5 Reboot the dedicated music on hold (MoH) server(s) one at a time. Switch to the new version of Unified CM.
Step 6 Reboot the backup subscriber(s) one at a time. Switch to the new version of Unified CM. This step might impact some users if 50/50 load balancing is implemented.
Step 7 Fail-over the devices from the primary subscribers to their backups.
Step 8 Reboot the primary subscriber(s) one at a time. Switch to the new version of Unified CM.
With this upgrade method, there is no period (except for the failover period) when devices are registered to subscriber servers that are running different versions of the Unified CM software.
Note When upgrading from Unified CM 6.0 to Unified CM 6.1 or later releases, any changes made to user-facing call processing features in the active partition of the subscriber's database will be migrated to the new version of the database. Any other database changes made in the active partition of the publisher's database will not be migrated to the new version of the database.
Cheers!
Rob
209
