CUCM Users error access
Hello
I have an issue when the user try to access to personal directory from ip phone, because the userid have a character @, for example user@domain.com and the CUCM return the following error:
Error procesing request
PD Error message
Can you help me?
Cisco Unified Communications Manager: 9.1.1.20000-5
Regards.
Carlos Sanz
1 REPLY
Hi Carlos,
Are you sure that the issue is happening with only the user id's having '@' character. Does the login work if using an id without '@'?
There is a very prominent bug in CUCM 9.1.1 where PD login does not work if the phones are registered with a subscriber.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCue60831
Workaround:
- Add entries to PAB via CCMUser page
- We can also register the phones to Publisher  ( not recommended  procedure for a cluster, but if there are few phones with little call  processing, we can resort to this. )
NOTE:  Due to changes in architecture, this defect is not applicable to  UCM 10.x and higher.
Permanent fix is to upgrade to 9.1.2 or the latest ES of 9.1.1.
Please let us know if this indeed was the issue or not.
Manish
178
