Community Member
CUCM v6 Cluster
A new cluster member reports that it can not communicate with the primary, though the security password and network information is correct. Any suggestions would be helpful.
Re: CUCM v6 Cluster
I have had this happen before! Did you change the Server name in the CUCM admin of the publish. perhaps from Hostname to IP? Also any firewalls in between? lastly are any other subs working or is this the first one?
HTH,
Chad
Community Member
Re: CUCM v6 Cluster
Thanks for the reply Chad. This is the first sub. Everything else has remained the same.
Community Member
Re: CUCM v6 Cluster
Did you find a solution to your problem? I'm asking because I have the same issue..
113
