CUCM v8.6.2 Database Communication Error
I have CUCM version 8.6.2.20000-2 running on VMware ESXi v5.0.0, and when it was restarted there was the error Database Communication error, there was no IP Address or hostname change, "A Cisco DB" service is not running:
admin:utils service list
A Cisco DB[STOPPED]  Component is not running
... and cannot be started:
admin:utils service start A Cisco DB
Service Manager is running
A Cisco DB[STARTING]
A Cisco DB[NOTRUNNING]
What can I do on this situation??  Any ideas that could help me??
It's a single node, this is the server information for CUCM server:
VMware ESXi v5.0.0
2 vCPU: Intel(R) Xeon(R) CPU E5506 @2.13GHz
Disk 1: 500GB
12288 Mbytes RAM
Juan Carlos Arias
  • IP Telephony
Everyone's tags (3)
utils service stop A Cisco DB •
utils service start A Cisco DB •
Stop the CEF service from serviceability page • utils service stop A Cisco DB •
Qiyu, I can't initiate any GUI service, I'll try it with OS Administration and post the results.
Thanks for your comments.
Can't troubleshoot cause DB is not running, and it's not started:
admin:utils dbreplication runtimestate
Database is down: please restart the database before reattempting a status check
I appreciate all the ideas that could help for a solution.
Do you have a backup? You can make a fress install as last resource...
Please remember to rate useful posts clicking on the stars below. Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo. ___________________________________________ LinkedIn Profile: do.linkedin.com/in/leosalcie
Hi Juan,Please, i have a
Hi Juan,
Please, i have a similar problem of Cisco DB not running, am sure you would have eventually solved the problem. Please share with me how you did it. Thanks
Ope
Hi opeyemityusuf,
Hi opeyemityusuf,
 first of all, use the following command to check your problem:
show perf query class "Number of Replicates Created and State of Replication"
Regards.
Thanks,Once i get this done,
Once i get this done, i will send the details.
3542
