CUCM V8 License
I need to rebuild the system, and to avoid having to get the license re-
homed I need to ensure the License MAC is the same. I have all the previous information except the details entered
for Ogranization/state/location etc. Where can I find these on the current system? I've look in lots of places but not found them yet, they must be staring at me somewhere....
1 ACCEPTED SOLUTION
Super Bronze
Re: CUCM V8 License
Those details go into the SSL certs, so you can look at the cert properties on IE to see them under 'Subject' on the details tab.
Alternately you can try 'show web-security' on the server CLI.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Re: CUCM V8 License
Aaron
Re: CUCM V8 License
Aaron, Excellent thanks, that was spot on. I was also then able to pre-check it with the license tool:
http://www.cisco.com/web/cuc_afg/index.html
273
