Community Member
cucm version 6.1.2.1139-3 is freezing
hello
my nam is shoham shalom from bezeq international,israel
i have a problem with cucm version  6.1.2.1139-3, that from time to time freezing(pub and sub)
and the only way to release this freezing is to reset manualy the servers.
as a resolte of freezing ,no acces at all,agent could not registered to the cucm
need a quick help
tk
shoham
1 REPLY
Silver
Re: cucm version 6.1.2.1139-3 is freezing
hello,
To start with, please get the output of the following commands from both the servers.
show status
utils core list
show hardware
How often is the issue happening.
I would suggest you to open a TAC case, as we would need tomcat, perfmon, amc,ccm and few other logs, and need to go through them to understant the cause.
Also you might consider and plan to upgrade the ccm version.
Kunal
251
