10-08-2013 06:41 AM - edited 03-16-2019 07:46 PM
I am looking for a solution that will allow me to force the requirement of a password (or code) for all placed calls (internal, external, LD and international) from one set connected to my CUCM. This particular phone is located in the Computer Lab at a High School. Often students are in the Lab unsupervised and I do not want anyone to be able to use this set. Only Teachers.
I have attempted the use of Extension Mobility, this created further confusion for the reception staff as they were not sure who they were transferring calls to; and users often neglected to logout of EM when leaving the room.
I am kicking around the idea of adding additional Line and Device Calling Search Spaces with Forced Authorization Codes; however to the best of my knowledge a FAC will not prompt for an internal call.
Has anyone experienced this before?
Any solutions or ideas?
Please advise.
Thank you
Solved! Go to Solution.
10-08-2013 07:02 AM
You're correct, natively, the best you can get is EM, FAC/CMC only work on outbound calls via a RP.
You can search CSC and you can find some 3rd party solutions to lock the phones.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-08-2013 07:02 AM
java
10-08-2013 08:49 AM
thanks
