CUCM Version 9.X generate alerts every day
Hi To all
I receive everyday alerts that two nodes from the cluster are down
ServerDown occurred.
Node 10.10.1.1 is unreachable.
Node 10.10.1.2 is unreachable.
We have a cluster of four cucms
First ucs server located to the building A and holding the below cucms
10.10.0.1
10.10.0.2
Second ucs server located to the building B and holding the below cucms
10.10.1.1
10.10.1.2
Building A connected with Building B with dark fiber
Checked  the interface into the layer 3 devices on both sides  and are clear
No errors no drop packets
check the output from the replication status
The ping msec is acceptable?
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
DB CLI Status: No other dbreplication CLI is running...
Cluster Replication State: Replication status command started at: 2014-03-20-09-56
     Replication status command COMPLETED 603 tables checked out of 603
     Errors or Mismatches Were Found!!!
     Use 'file view activelog cm/trace/dbl/sdi/ReplicationStatus.2014_03_20_09_56_34.out' to see the details
DB Version: ccm9_1_1_10000_11
Repltimeout set to: 300s
PROCESS option set to: 1
Cluster Detailed View from CM1 (4 Servers):
                                PING            CDR Server      REPL.   DBver&  REPL.   REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    (ID) & STATUS   QUEUE   TABLES  LOOP?   (RTMT) & details
CM1     10.10.0.1      0.032   Yes     (2)  Connected   0      match   Yes     (2) PUB Setup Completed
CM2     10.10.0.2      0.099   Yes     (3)  Connected   0      match   Yes     (2) Setup Completed
CM3     10.10.1.1      1.378   Yes     (4)  Connected   140    match   Yes     (2) Setup Completed
CM4     10.10.1.2      1.232   Yes     (5)  Connected   140    match   Yes     (2) Setup Completed
Regrds
cc
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Hi,Your cluster could be
Your cluster could be affected by the following bug
https://tools.cisco.com/bugsearch/bug/CSCtl75789
Symptom:
The RTMT receives a false alarm that the Server is down.
Conditions:
Any error in the network that closes the TCP session on the ports 1090 and 1099 will cause the false alarm.
Workaround:
none.
Manish
Hi Manish I have put 5 points
Hi Manish
I have put 5 points and didn't mark the question as answered since we are not sure yet if this is the issue
The cucm running version 9.1.1.10000-11
Is not fixed into this version
Do you have any other step to check?
Hi,I have seen a few TAC
I have seen a few TAC cases where this bug is suspected for the server down alerts even on cucm 9.1.X. As the bug is still in Open state, i would suggest opening a TAC case so that they can verify the same by taking packet captures from callmanager servers.
Manish
226
