CUCM version upgrade from 8.5.1.11900-21 to 8.6.2.23900-10
Hi All,
I am planning for CUCM version from 8.5.1.11900-21 to 8.6.2.23900-10 . We have only 2 servers. Need to know whether any challenges are there prior to this upgrade like cop file "ciscocm.refresh_upgrade_v1.2.cop.sgn" need to be applied, phone firmwares to be checkedand so on.
Sankar.
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
No challanges, simply follow the upgrade guide and you should be good to go.
HTH,
Chris
Re: CUCM version upgrade from 8.5.1.11900-21 to 8.6.2.23900-10
As a best practice you should always review the RNs when upgrading, anything out of the ordinary will be there
java
if this helps, please rate
www.cisco.com/go/pdi
HTH,
Chris
Hi Chris,
I was able to upgrade successfully. Only thing is i have applied "ciscocm.refresh_upgrade_v1.1.cop.sgn" file prior to the upgrade.
Thanks a ton.
Sankar.
java
283
