02-28-2014 01:43 AM - edited 03-18-2019 11:20 AM
Hi All,
Current Call flow.
EP --> CUCM ---> Avaya SM ---> VCS -- > EP. Calls are always maturing as Audio Call. While checking the CUCM logs CUCM remove the Video capability in their SDP message.
When we are sending the call via direct trunk between CUCM & VCS video calls are woking fine.
Solved! Go to Solution.
03-08-2014 06:15 AM
Hello Sriram,
it seems the RSVP policy is disallowing the video call.
06647405.003 |12:12:13.844 |AppInfo |SIPCdpc(18750684) - outCall_waitRSVPRes_PolicyAndCACRegisterRes: RSVP disallowing video call.
06647405.004 |12:12:13.844 |AppInfo |Locations_getLocPKIDAndName -- loc= 0; pkid= 29c5c1c4-8871-4d1e-8394-0b9181e8c54d; Name = Hub_None
06647405.005 |12:12:13.844 |AppInfo |Locations_getLocPKIDAndName -- loc= 15; pkid= a667d613-34fa-55f2-637f-abfdc54ab71a; Name = LOC-TBM-SIP-AVAYA AURA
>> so there is no video in the sdp.
06647405.009 |12:12:13.844 |AppInfo |SIPCdpc(18750684) - convertMediaSDPMsgToSDP:
SDP:: isPresent=1, role=1
numAudiomLines=1 numVideomLines=0
>> Please crosscheck the location settings & rsvp policy.
//Suresh
Please rate all the useful posts.
02-28-2014 02:34 AM
Few things you can check.
If you have enabled early offer on both the trunks( to Avaya SM and to VCS) , compare the SIP messages. See the initial INVITE sent by CUCM does they carry video in SDP media ?
If yes then check the return SDP reply from Avaya SM and VCS , do they remove video from media in response ?
That may help which side is not allowing media.
Manish
03-05-2014 12:45 PM
Hi Manish,
I have enabled the EO for the SIP trunk. SDP message from the CUCM to SIP trunk itself not having the Video capability.
Has anything we have to check in the Trunk or Region configuration ?
04-10-2014 01:53 PM
Hi Nishant, Manish, and Suresh,
As I found this thread interesting you might be able to help me on similar issue...I opened another thread and I appreciate if you could jump and see if you could point me on the right direction....Thanks!
https://supportforums.cisco.com/discussion/12171031/callvideo-not-working-between-cisco-jabber-windows-and-vcs-control-c40s
04-08-2015 12:09 AM
Hi All,
Current Call flow.
EP --> VCS ---> Avaya SM ---> CUCM -- > EP.
Calls are getting connected on both sides but, the issue here is i am receiving the call as
Alias@CUCM ip address for all the calls from both the sides.How to change the cucm ip address to VCS.domain
any help ?
02-28-2014 02:53 AM
Hi ,
Can you please share your detail trace from CUCM?
Is Avaya SM and VCS under your control? If yes then do send trace from respective.
Also mention calling number and called number?
Nishant Savalia
03-07-2014 02:42 AM
03-07-2014 05:09 AM
Hello Sriram,
what is the calling number, called number & time of call?
how do you enable EO on the SIP trunk? by checking MTP? or on SIP profile?
Have you checked "Early Offer support for voice and video calls (insert MTP if needed)" in the SIP profile applied to that SIP Trunk?
//Suresh
//Suresh
03-08-2014 06:15 AM
Hello Sriram,
//Suresh
03-08-2014 08:22 AM
Hi Suresh !
Thanks for your analysis. In Trunk Location is configured where no bandwidth allocated for the video .
Now the calls are working fine.
