Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CUCM Virtual Machine
I'm looking into adding a CUCM Subscriber into our cluster as a virtual machine in VMWare ESX 4.  I have two questions.
1.  Is it okay to have a couple of physical CUCM's and add a virtual subscriber to that cluster?
2.  How does the licensing work for that?  Is there just a CUCM software part number for ESX installs?  If so, what is the part number?
Everyone's tags (5)
3 ACCEPTED SOLUTIONS
Re: CUCM Virtual Machine
Virtualization is only supported with CUCM 8.x and only on Cisco UCS servers. It is possible to install CUCM in a VM outside of these parameters, but it will not be supported by Cisco.
Hope this helps.
Brandon
Since we do not support anything other than CUCM 8.0(2) in VMWare we do not sell anything associated to this scenario.
You would need to buy any associated PNs as if it was a regular MCS install.
The only thing before 8.0(2) we support on VMWare are the NFR kits.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
VIP Super Bronze
No. UCM 8.x will only be supported on Cisco UCS hardware. Third-party host support is a ways off.
Hope this helps.
Brandon
I understand that it isn't supported, but will the above scenario work?  If so, what is the part number?  Do I just a purchase a CUCM server seat?
java
java
8.0(2c) is out.  We are about to move to it.  Will it eventually have specific PN for VM loads?
VIP Super Bronze
1207
