cucm web gui
trying to setup a home lab to study for the ccna voice cert.
i installed cucm 8.6 on vmware workstation and worked fine.
i was able to get to the login page but when i login with the admin account, none of the navigation buttons are dropdowns like they're supposed to be.
can someone tell what i have to do.
1 ACCEPTED SOLUTION
cucm web gui
I'd think this is more a browser problem. try another one, different version, etc.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Silver
Re: cucm web gui
Hello Tony,
Did you comply with system requirements like RAM for example?
-David|Rojas|Peck
cucm web gui
pretty sure. i assigned 4gb ram and 90gb hard disk space (scsi)
cucm web gui
java
java
cucm web gui
it was the browser. i was trying it on chrome and ie, but both werent working
installed firefox and started working.
thanks.
194
