12-23-2011 01:08 AM - edited 03-16-2019 08:40 AM
I am having issue with CUCM web console, its showing only first page and when i click on Cisco Unified Communications Manager it keeps loading and never finishes. Can anyone help me to resolve this issue?
Solved! Go to Solution.
12-23-2011 02:44 AM
Restarting Tomcat will not impact your production. It is just to fix any web page related issues.
If you are concerned, you may do it during off-peak hour but absolutely nothing to worry as far as business impact is concerned.
Pls rate the post if it helps.
GP.
12-23-2011 01:13 AM
Pls post full version details of CUCM.
GP.
12-23-2011 01:41 AM
CUCM version is 8.6.1.2
12-23-2011 02:23 AM
Did you try restarting Cisco Tomcat service ?
Is it on on VMware, if yes ensure that it is not getting into any resource crunch, slowing the server response down.
GP.
12-23-2011 02:35 AM
Its in production environment, will it implact other services or only the webservices?
12-23-2011 02:44 AM
GP.
12-23-2011 02:54 AM
Hi GP,
I have restarted the tomcat service and its working fine now. Is there specific reason for such behaviour of tomcat?
thanks,
Amrish
12-23-2011 05:11 AM
Amrish,
Glad to hear that the issue is resolved now & thanks for the rating too.
Tomcat sometimes tend to hang due to some interdependancy that service has. Restarting Tomcat usually fixes such sluggish behavior, so no harm in doing it whenever you face such issue.
If my answer was the correct answer to your query, kindly mark it as Correct Answer.
Happy Holidays !!
GP.
