CUCM with HP and IBM server os version do not match
hi everybody
we have 1 cluster with 3 CUCMs with the release 6.1.3 and the CUCM reporting send the alert
with The os version on all servers do not match , historically the had to install
1 Pub (HP)
1 Sub (HP)
an 1 year after we had 1 Sub (IBM) more , I have read several articles on this site as is it  possible to have a cluster with HP and IBM so in my case is it a hardware problem
or  DVD release off CUCM isn’t correct
Thank you for your answers
Do a sh version on all servers and see what you get.
There's no way you could install a server into a cluster without using the exact same release you're running on the previous ones.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi Java ,
Thank you for that answer but on my cluster if I take look with Show version active
it's the same on 3 servers
do you have another idea
Br,
Abdenacer
216
