Community Member
CUCM with presence server
Hi All,
we are using CUCM 6.1 with Cisco presence server. everything is working nice. But based on Cisco documentation, we are supposed to see presence status of people when we check directory, corporate directory on the phone. Our doesn't show presence status. if you show me how to get it to work, I'll be very apprciated.
thanks
Alex
1 ACCEPTED SOLUTION
Re: CUCM with presence server
I found the Enterprise Parameter "BLF For Call Lists"
Cisco Unified CallManager Call History Presence
Cisco Unified CallManager supports presence capabilities for call history lists (the Directories button on the phone). Call history list presence capabilities are controlled via the BLF for Call Lists Enterprise Parameter within Cisco Unified CallManager Administration. The BLF for Call Lists Enterprise Parameter impacts all pages using the phone Directories button (Missed, Received, and Placed Calls, Personal Directory, or Corporate Directory), and it is set on a global basis.
Presence capabilities for call history lists are supported for both SCCP and SIP on the following Cisco Unified IP Phones:
Cisco Unified IP Phones 7941G and 7941G-GE
Cisco Unified IP Phones 7961G and 7961G-GE
Cisco Unified IP Phones 7970G and 7971G-GE
The Cisco Unified IP Phones 7905G, 7906G, 7911G, 7912G, 7940G, and 7960G do not support presence capabilities for call history lists.
The presence indicators for call history lists are the same as those listed in the Icon Indicators for Speed Dial Presence ; however, ***no LED indications are available.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guide_chapter09186a008070bc02.html#wp1070690
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
From this doc;
java
java
367
