Community Member
CUCM6.1.3 https certificate problem- need help
I have an issue when opening a browser window to my subcriber
https://ukldnccm01/ccmadmin
I get the following message
"The name on the security certificate is invalid or does not match the name of the site"
I checked the certificate on the cucm6.1.3 OS administration page and tomcat_cert.pem looks ok
however when i look at the actual certificate issued to ie6 on my p.c it seems to be getting the wrong certificate from somewhere, its a different serial number and the name is missing on the issuer. But i cant see how i fix it. Does anyone have any ideas?
issuer
CN=
OU=UKLDN
0=my organisation
L=UK
s=Lonodon
C=GB
the lines below also have missing entries
also issued to:
issued by:
certification path is also empty
regards
colin
1 ACCEPTED SOLUTION
Red
Re: CUCM6.1.3 https certificate problem- need help
A couple questions:
1) Are you using the default (self-singed) certificate for Tomcat or a 3rd-party signed certificate?
2) Did you restart Cisco Tomcat after uploading the certificate?
3) If you use a different web browser (such as FireFox), would you get the same certficate?
Thanks!
Michael
http://htluo.blogspot.com
Red
A couple questions:
Thanks!
Michael
Community Member
Hi Mike
Thanks for the fast response.
answers to your questions
1) its the self-signed certificate
2) no i didnt restart tomcat
3) i do get the same certificate with firefox
colin
Community Member
Hi Mike
I restarted tomcat and the correct certificate was found and all is ok now.
Thanks very much for your help
colin
175
