Community Member
CUCM6.1 - Allowing calls only to specific numbers
Hi!
I would like to know what is the best way to allow a device connected to an ATA to just be allowed to call the following numbers: 800 205 603, 44 179 381 4841.
Ana
Silver
Re: CUCM6.1 - Allowing calls only to specific numbers
Create a Partiton called "Restricted Number ATA ONLY " or something, create a new CSS " css_ATA ONLY"???
Create a route pattern for the numbers you only want the ATA to call and assign the new Partiton to them ATA ONLY-"Restricted Number ATA ONLY" , assign the new CSS to the ATA devices. This way only the route patterns you have assigned to the Partiton "Restricted Number ATA ONLY" and only phones you assigned the CSS -"css_ATA ONLY" will be able to make calls- hope it helps
Bronze
Hi Ana, I think that a nice way is to use partitions, put these numbers and your ATA Line in a unique partition and make sure that the CSS has the partition that you crated for these numebrs and device.
Hope this help
David
Community Member
Ok. Thank you all.
112
