08-24-2010 05:33 AM - edited 03-16-2019 12:26 AM
is it normally that the CUCM has such high memory workload?
Is it imaginable because of high memory load that as example the
"Cisco AXL Web Service" is not reachable or other services like Web Administration.
######################SHOW-Beginn####################
admin:show memory module 1
Bank Locator Size Status
DIMM 1 DIMM 1 1.0GB OK
admin:show memory module 2
DIMM 3 DIMM 3 1.0GB OK
admin:show memory
show memory count
show memory module
show memory size
admin:show memory si
admin:show memory size
Total size of memory: 2.0 GB
admin:show status
Host Name : CUCM6-P
Date : Tue Aug 24, 2010 13:59:24
Time Zone : Europe/Berlin
Locale : en_US.UTF-8
Product Ver : 6.1.4.2000-2
Platform Ver : 2.0.0.1-1
Uptime:
13:59:25 up 19:20, 1 user, load average: 0.04, 0.04, 0.00
CPU Idle: 92.50% System: 03.00% User: 03.50%
IOWAIT: 00.00% IRQ: 00.00% Soft: 01.00% Intr/sec: 132.00
Memory Total: 2053840K
Free: 22436K
Used: 2031404K
Cached: 677696K
Shared: 0K
Buffers: 55304K
Total Free Used
Disk/active 43453524K 31793424K 11218636K (27%)
Disk/inactive 43453556K 41213400K 32828K (1%)
Disk/logging 151179108K 120900536K 22599104K (16%)
admin:show process load
13:57:52 up 19:19, 1 user, load average: 0.08, 0.04, 0.01
120 processes: 119 sleeping, 1 running, 0 zombie, 0 stopped
CPU states: cpu user nice system irq softirq iowait idle
total 0.0% 0.4% 0.0% 0.0% 0.0% 0.0% 99.5%
cpu00 0.0% 0.9% 0.0% 0.0% 0.0% 0.0% 99.0%
cpu01 0.0% 0.0% 0.0% 0.0% 0.0% 0.0% 100.0%
Mem: 2053840k av, 2034900k used, 18940k free, 0k shrd, 55220k buff
1512636k actv, 299692k in_d, 35212k in_c
Swap: 2048248k av, 476952k used, 1571296k free 682532k cached
PID USER PRI NI SIZE RSS SHARE STAT %CPU %MEM TIME CPU COMMAND
10631 admin 34 10 1384 1384 960 R N 0.4 0.0 0:00 0 top
1 root 15 0 704 588 524 S 0.0 0.0 0:04 0 init
2 root RT 0 0 0 0 SW 0.0 0.0 0:00 0 migration/0
3 root RT 0 0 0 0 SW 0.0 0.0 0:00 1 migration/1
4 root 15 0 0 0 0 SW 0.0 0.0 0:00 0 keventd
5 root 34 19 0 0 0 SWN 0.0 0.0 0:00 0 ksoftirqd/0
6 root 34 19 0 0 0 SWN 0.0 0.0 0:00 1 ksoftirqd/1
9 root 15 0 0 0 0 SW 0.0 0.0 0:00 0 bdflush
7 root 15 0 0 0 0 SW 0.0 0.0 0:02 1 kswapd
8 root 15 0 0 0 0 SW 0.0 0.0 0:14 0 kscand
######################SHOW-End####################
08-24-2010 05:39 AM
It's normal for CCMs to use a lot of memory, and not have much disk space.
It's also quite a fine line between 'normal' and 'broken' sometimes... there have been a lot of memory-leak type bugs which generally exhibit themselves first as problems with Tomcat (so any user/admin web pages, AXL, etc).
Generally the answer is an upgrade IF you are experiencing such issues. If it just looks like it's using a lot of memory but is otherwise working; don't worry about it.
Aaron
Please rate helpful posts..
