Community Member
CUCM6.1 Subscriber and CDR
my first node the Publisher is down and only one Subscriber is running of that cluster now.
1.Is it possible to get the CDR data to a Billing Application Server?
2. Will be written CDR data in that case?
I checked the Services and CDR Management, they seem to be ok.
Cisco CDR Repository Manager Running
Cisco CDR Agent Running
Cisco CAR Scheduler Running
1 ACCEPTED SOLUTION
Re: CUCM6.1 Subscriber and CDR
Call Detail Records (CDR) and Call Management Records (CMR)
Call detail records and call management records, when enabled, are  collected by each subscriber and uploaded to the publisher periodically.  During a period that the publisher is unreachable, the CDRs and CMRs  are stored on the subscriber's local hard disk. When connectivity is  re-established to the publisher, all outstanding CDRs are uploaded to  the publisher, which stores the records in the CDR Analysis and  Reporting (CAR) database.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/models.html#wp1044074
Above from SRND
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Above from SRND
java
java
Community Member
Yes this was helpful!
Thank you!
236
