Bronze
CUCM6 Mobility Softkey - AD Integration
I'm troubleshooting an issue with the Mobility softkey in CUCM6. CUCM6 is integrated to AD and I know that I need to set the Owner User ID to get this to work, but this is not possible with an AD integration as far as I've been able to tell.
Does anyone have a fix or recommendation for this? A service parameter perhaps?
Thank you,
Jon Nelson
1 ACCEPTED SOLUTION
Green
Re: CUCM6 Mobility Softkey - AD Integration
Hi again Jon,
Even with AD Integration you should be able to use Owner User ID, check if EM is enabled. If that is correct disable it and test.
If you enable Extension Mobility, even after Owner User ID was configured, it
becomes grayed out and the Mobility softkey stops working.
It's even listed in the help screen that Owner User ID and EM are mutually exclusive.
Extension mobility does not support device owners.
Let us know
Green
Hi again Jon,
Let us know
Bronze
That was it. Thanks again Gonzalo. That's two I owe you!
Thank you,
Jon Nelson
What is the proper way to use Mobiliy and Extension Mobility on the same phone?
138
