10-13-2009 07:36 AM - edited 03-18-2019 10:44 AM
I am having so much trouble figuring out how to get two internal networks to talk to each other inside my home. This may be an easy question, but I am truly stuck. My goal is to have CUCM7.1x (192.168.8.2)installed inside VMware 6.5 Workstation(Host is located on 192.168.7.0 network) talking to my 7940 IP phone so I can test CUCM features.
I have a Verizon Fios(ISP) router with internal IP of 192.168.7.1.(DHCP turned OFF)
I have a Linksys SD2005 5-port switch and a DHCP server handing out IP addresses on an SBS 2003 server. I created 2 scopes(192.168.8.0 and 192.168.7.0)
I am configuring my Cisco 1811 router and using a cable connected to the Linksys switch.
I created a VLAN10 with IP address of 192.168.7.254 and an IP Helper address of 192.168.7.2 (DHCP server)
I created VLAN50 with IP address of 192.168.8.1
BOTH VLANs are UP,UP.
There is an 8-port switch onboard plus 2 fast ethernet ports 0 & 1.
I inserted a static route on my FIOS router: 192.168.8.0 255.255.255.0 192.168.7.254
I connected the cable from the Linksys Switch to the FASTETHERNET 9 port on the 1811 router.
I can't ping 192.168.8.1 from a workstation located on the 192.168.7.0 network.
I can't ping 192.168.7.254 from a bridged virtual machine on the 192.168.8.0 network. I can't even ping it's gateway 192.168.8.1 address which is part of the network!
The router config is as follows:
version 12.4
hostname JMF-1811
boot-start-marker
boot system flash c181x-adventerprisek9-mz.124-22.T3.bin
boot-end-marker
logging message-counter syslog
enable secret 5 $1$kUOG$5A8boTa6J.al/MLEzKSml0
enable password ***************
no aaa new-model
dot11 syslog
ip source-route
no ip routing
no ip cef
no ipv6 cef
archive
log config
hidekeys
interface FastEthernet0
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface FastEthernet1
no ip address
no ip route-cache
speed auto
half-duplex
interface FastEthernet2
switchport access vlan 50
switchport voice vlan 10
interface FastEthernet3
interface FastEthernet4
shutdown
interface FastEthernet5
shutdown
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
shutdown
interface FastEthernet9
interface Vlan1
description MANAGEMENT VLAN to local LAN
ip address 192.168.77.1 255.255.255.0
ip virtual-reassembly
no ip route-cache
no ip mroute-cache
interface Vlan10
description VOICE-VLAN
ip address 192.168.8.1 255.255.255.0
ip helper-address 192.168.7.2
interface Vlan50
description DATA-VLAN
ip address 192.168.7.254 255.255.255.0
interface Async1
no ip address
encapsulation slip
no ip route-cache
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.7.1
no ip http server
ip http secure-server
control-plane
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
login
end
10-13-2009 07:51 AM
From what I can see of the config you haven't created the layer 2 vlans.
conf t
vlan 10
exit
vlan 50
exit
Once these have been created you should be able to ping between the VLANs.
10-13-2009 07:58 AM
Hmmm...I thought I did this already....look here:
interface Vlan10
interface Vlan50
10-13-2009 10:59 AM
Hi, apply the "ip routing" command. You have "no ip routing"
Hope this help
David
10-13-2009 11:22 AM
OK...I added that, but I can't ping my DHCP server(192.168.7.2) from the router.
I can ping 192.168.8.1 and 192.168.7.254, which are both local router ports.
I am connected via FastEthernet 9 interface.
