Bronze
CUCM7+CUC7 and missed calls
Hi friends, I have a CUCM7, CUC7 with VoiceMail and AutoAttendant. When a user check the PSTN incoming missed calls on the IP Phone, it only shows the CTI number configured for the AA.
I want that the IP Phone show the "real" missed call and not the CTI number, so,
If you have any suggestion, please let me knows to resolve this incovenient.
Thanks a lot
David
Re: CUCM7+CUC7 and missed calls
Hi there,
You will want to configure forwarded call information display on the CTI Route Point to Redirected Number.
Forwarded Call Information Display
Caller Name
Checking this check box will cause the caller name to display upon call forward.
Redirected Number
Checking this check box will cause the number that was redirected to display upon call forward.
Caller Number
Checking this check box will cause the caller number to display upon call forward.
Dialed Number
Checking this check box will cause the original dialed number to display upon call forward.
HTH, Please vote if this helps.
Justin
Bronze
Hi Justin, thanks for your mail and sorry for the late response. I tried your suggestion but it is not working yet. I noticed that the missed number that shows the VoiceMail Port instead of the real calling party number only appears in the IP Phone 7941/61. I upgrade the firmware to 8.5 but no results.
If I'm missing something please let me known.
Thanks again
David
Bronze
Hi all, I upgrade the IP Phone 7941/7961 to the latest firmware but with no results. The missed calls only shows me the VoiceMail port number. Does any one has a similar issue or a suggestion. It only happens with this IP Phone model, all the other models (7940/7960) are working fine.
Thanks a lot forum
David
Bronze
David,
I have been fighting this same issue on call forwards from UCCX scripts as well. I was considering moving the AA in question to CUC in hopes that it would work differently. From your post, I see that it doesn't.
I am currious from your last post. Are you saying that 7940/60 phones are showing the callers caller-id and not the CTI port number? If this is the case, then Cisco has gone backward with the 7941/61 phones. I assumed it would be the same on all phone models. I need to test this on our newer 7962 phones to see if it works on them.
Mark
Hall of Fame Super Red
Hi Mark,
Have you tried playing with this setting?
CallManager System Parameter:
Clusterwide Parameters (Device - Phone)
Display Original Calling Number on Transfer from Cisco Unity = True
When we changed this parameter from the default = False to True the proper
clid is shown on transfers from UC 7.1 AA to the following tested models;
7940/7960
7941/7961
7942/7962
7945/7965
Cheers!
Rob
Bronze
Rob,
Thanks for the reply. Since the functionality of calls tranfered from Unity Connection to phones can be changed with a service parameter, wouldn't it sound feasible that the same thing could be done for UCCX call transfers? I sent a feature request to my Cisco rep about this. I started a new thread on this for the UCCX issue and posted all of the messages I had sent to my Cisco rep in hopes that a Cisco developer can shed some light on this with UCCX.
Mark
Bronze
Hi Mark, I change the service parameters value as Rob suggest but the result was the same only for the ip phones 7941/61. I was working with CUCM 7.0 and CUC 7.0, but, as Rob mentioned, may be with version CUCM 7.1 / CUC 7.1 there is no problem.
I will try with this version and I'll let you know asap.
hth
David
Have you tried setting "Display CTI Route Point Name or DN" service parameter to "False" ?
- Sriram
Bronze
Sriram,
Disply CTI Route Point Name or Number is for redirected calls and not transferred calls.
Mark
624
