12-24-2008 03:48 AM - edited 03-15-2019 03:13 PM
Hi All,
We have a customer considering a CUCM7 cluster configured for LDAP synchronization with Microsoft AD 2003. In this scenario is it possible to synch the Alerting Name, Display and Line Text Label of a DN to the users name in Active Directory? Had a bit of a look around and it doesn't seem to be possible but I don't have any experience with CUCM7 or AD synch, wondering if anyone has come up with a solution?
Jonathan
Solved! Go to Solution.
12-24-2008 07:08 AM
Sorry this can not be done natively in CM. You would need to configure some kind of a tool that would update the device tables with this information.
HTH,
Chris
12-24-2008 07:08 AM
HTH,
Chris
12-24-2008 07:15 AM
Thought that was the case, thanks for the confirmation.
