CUCM8.6 DB replication
Hello all.,
I had change in IP address on my CUCM Cluster, which has a Publisher and one Subscriber.
I followed changing IP address procedures as below-
1)Changed SUB IP Adds from CM PUB Admin Page.
2)Changed the Gateway and IP from SUB CLI. Restarted.
3) Changed PUB IP from SUB -OS Admin and then again Restarted.
4) Changed PUB Ip from Pub Admin page
5)Changed PUB GW and IP from PUB CLI and restarted the Box.
Now when i check the DB Replication- i could see PUB Status: 2- Good
But Sub Its shows N/A.
Iam able to access both servers from GUI, and CM and TFTP,DB Repl. Services are up in both servers.
I restarted the servers couple of times..
Any clue why Subscriber shows N/A in replictaion status.
Bobby
1 ACCEPTED SOLUTION
Re: CUCM8.6 DB replication
Hi Bobby,
Absolutely.. you need to setup your forward and reverse lookups on your DNS server
Once that is done, you need to test with ssh on the pub
run the foll
utils network host   you should see local and external resolution resolving correctly repeat the process for sub.
once that is in place perform
utils dbreplication stop on sub
utils dbreplication stop on pub
utils dbreplication reset all from pub.
Hope tis helps
Niket
Hi Bobby,
Have you tried to do the following?
1. utils dbreplication stop - on all nodes, first on the SUB, then the PUB
2. utils dbreplication reset all - on PUB
NOTE:  It is recommended to run this procedure during off-peak hours, because can increase CPU usage.
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
Hall of Fame Super Silver
Have you see this great doc:
https://supportforums.cisco.com/docs/DOC-13672
HTH,
Chris
Thanks testeven,
I had done the dbreplication as mentioned above, but iam getting replication status as,
Pubisher shows- good.
Subscriber- N/A
  10.105.100.110
  2 - good
  10.105.100.111
  N/A
  N/A
admin:utils dbreplicatio
SERVER-NAME     IP ADDRESS      (msec)  RPC?    STATUS          QUEUE   TABLES L                                   OOP?    (RTMT) & details
CUCM-P01   10.105.100.110  0.035   Yes     Off-Line        N/A     match  Yes      (2) PUB
CUCM-S01   10.105.100.111  0.134   Yes     Off-Line        N/A     match  N/A      (4) N/A
admin:
Does the replication fail if the CUCM Servers not reachable to DNS Server.?
Bobby
f
Hi Bobby,
run the foll
Hope tis helps
Niket
Well, it should work even without DNS as it uses local host files.  For me typcially the ultimate solution is this procedure, just did it the other day for same scenario you are describing where servers were not in DNS either:
  1. utils dbreplication dropadmindb - Issued on SubscriberB to  restart the syscdr on that node.
  2. utils dbreplication stop - Issued on SubscriberB
  3. utils dbreplication reset subscriberB - TO once again try to reestablish the connection after fixing the corrupted syscdr.
HTH,
Chris
Just to add here, you need to be patient as well as this may take some time.
Chris
Re:CUCM8.6 DB replication
Well there is a reason ,when you populate dns your .rhosts files are setup with fqdn not the hostname, now when dbrepln setup request comes in it will look.for the entry of.the .rhosts and then resolve it.locally which wouldn't work and when it looks at external resolution if yoy dont have dns correctly it would fail therwby breaking dbrepln.
Sent from Cisco Technical Support Android App
Thanks nikshah and chris,
It was the DNS issue, Replication shows "good".
Tnx
Bobby
Hello all,
Please take a look at the blog and video I posted on dbreplication runtimestate:
Blog url: https://supportforums.cisco.com/community/netpro/collaboration-voice-video/ip-telephony/blog/2012/10/26/understanding-cucm-dbreplication-runtimestate
Please feel free to provide your feedback and any additional questions you may have on this topic.
Harmit.
-- Regards, Harmit.
738
