CUCM9.1 :: Blind Transfer - call return on no answer
Is there a feature in CUCM9.1 to have a call return to the transferer after a blind transfer to an extension which does not pick up ? No VM involved.
thanks in advance
Paul.
2 ACCEPTED SOLUTIONS
Hi Paul.
Because with the blind trnasfer feature, the transferer is totally disconnected after transfer, I think is not possible.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Super Bronze
No - some Operators consoles such as Arc (and the CUxAC version) do this, but CUCM doesn't have it built in.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Paul.
Carlo
Super Bronze
Aaron
170
