Community Member
CUCMBE 6000 LIC
Hi Support,
I have installed CUCM/CUC 6000 (UCS C200 M2) Exsi.4.1.0  i use ova taplates for both now i need to install the .lic which MAC should i chose i didnt understand do i have to configure manually this is the network output for CUCM what if i reinstall these MAC will remain same???
DHCPdisabled
StatusUp
IP Address10.10.5.5
IP Mask255.255.255.000
Link Detectedyes
Queue Length1000
MTU1500
MAC Address00:0c:29:5c:f8:7e
License MAC6a3cacbd1a51
RX Bytes356175
RX Packets2637
RX Errors0
RX Dropped0
RX Overrun0
RX Multicast0
TX Bytes2445227
TX Packets1088
TX Errors0
TX Dropped0
TX Carrier0
TX Collisoins
For Unity Connection
DHCPdisabled
StatusUp
IP Address10.10.5.6
Link Detectedyes
Queue Length1000
MTU1500
MAC Address00:0c:29:9c:04:07
License MAC0a849e42d4e7
RX Bytes277824
RX Packets2636
RX Errors0
RX Dropped0
RX Overrun0
RX Multicast0
TX Bytes1594214
TX Packets878
TX Errors0
TX Dropped0
TX Carrier0
TX Collisoins0
Sheraz
3 ACCEPTED SOLUTIONS
CUCMBE 6000 LIC
Then you use the respective license MAC to license each system
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hall of Fame Super Silver
CUCMBE 6000 LIC
Use the License MAC 6a3cacbd1a51 for all licensing with this version, once you go to version 9+ it becomes irrelevant due to ELM implementation.
HTH,
Chris
CUCMBE 6000 LIC
1. See this thread:
https://supportforums.cisco.com/thread/2177324
2. this is OVA for provisioning manager, if you want to install and use it this the OVA template for it.
HTH, please rate all useful posts!
Chris
CUCMBE 6000 LIC
What versions are you using???
It all depends upon that fact, and you're not mentioning it.
java
java
Community Member
CUCMBE 6000 LIC
Hi Sir,
Thanks for  quick reply we  ordered all the lic for 6K CUCM/CUC are installed up and running EXSi version 4.1 vSphare 4.1 registered version (UCS C200 M2 rack mount server )
CUCM 8.6.2a
CUC    8.6.2a
Regards ,
Sheraz
CUCMBE 6000 LIC
java
java
CUCMBE 6000 LIC
HTH,
Chris
Community Member
CUCMBE 6000 LIC
Hello Sir ,
First of all thanks you very much for help okay i will use CUCM  License MAC for CUCM and Unity License MAC for CUC.
I have only 2 questions now your help will be appreciated.
1) If something happend or crash software and i need to reinstall the CUCM and CUC on same server from scratch the LIC MAC will change or remain same for both product CUCM/CUC 8.6.2a or i can backup and restore? .
2) what is this file for (cupm_8_6_linux_vmware.ova) i received with the bundle  i need to install this or its okay to contnue because i install this and its asking for username and password.
Please correct me.
Thanks In Advance
Sheraz
CUCMBE 6000 LIC
1. See this thread:
Chris
134
