01-16-2009 08:13 AM - edited 03-15-2019 03:34 PM
Just a quick question for the experts out there. Is CUCMBE 7 capable of being integrated with Presence 7? I was looking at this compatibility matrix and did not see the answer yet I am hearing that this is possible.
http://www.cisco.com/en/US/docs/voice_ip_comm/cups/7_0/english/compatibility/cupcompatibility7x.html
Solved! Go to Solution.
01-16-2009 09:06 AM
Ah... looks like they start supporting LDAP from 7.0
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/cmbe.html#wp1045575
"Beginning with Release 7.0, Unified CMBE supports corporate directory integration"
It was not supported on CUCMBE 6.x.
01-16-2009 08:46 AM
Yes, it is compatible.
However, since CUCMBE does not support LDAP integration, you might run into some potential problems.
See details on my blog:
01-16-2009 09:00 AM
Thanks for the link. Bookmarked for future reference!
I am looking through the Admin guide for CUCMBE and it shows LDAP as being a configurable option. Is this incorrect?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/admin/7_0_1/ccmcfg/b02ldsys.html
Also release notes showing LDAP
01-16-2009 09:06 AM
01-16-2009 09:02 AM
CUCMBE 7 does support LDAP, it's one of the enhancements made
LDAP Support in Cisco Unified Communications Manager Business Edition
Cisco Unified Communications Manager Administration Guide for Cisco Unified Communications Manager Business Edition, Release 7.0(1)
LDAP System Configuration
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucmbe/admin/7_0_1/ccmcfg/b02ldsys.html
EDIT: you beat me by 2 minutes Matt =)
java
if this helps, please rate
01-16-2009 09:10 AM
Thanks! This will make this install much easier.
Matt
