04-02-2012 12:58 PM - edited 03-16-2019 10:26 AM
Is it possible to turn on/off the auto attendant from the phone. Currently the auto attendant is setup on time based schedule. Thanks in advance.
04-02-2012 01:05 PM
Not without some custom development. You could for example control it via callFwdAll feature for example.
Chris
04-02-2012 01:20 PM
Where do I find the extension for the auto attendant so I can do a callfwdall from the phone that answers the main line during business hours. I see an extension in System handlers in cisco uity connection administration, but when I dial that number it says invalid.
Thanks.
04-02-2012 01:05 PM
Unless you have the DN from such phone that you can do a CFA (or disable CFA) to the AA DN, there's no way.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
