CUCMBE as a Backup
Can we use CUCMBE as A backup for Our CUCM ?
because we have CUCM and now all the phones are register on it so can we use the unused CUCMBE to be as backup for the CUCM
regards
Talaat
CUCMBE as a Backup
Not as a CUCMBE, only if you turn it into a full CUCM and make it a SUB for the other cluster.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
CUCMBE as a Backup
Hi Java
thanks for your replay, to turn our CUCMBE to be CUCM and make it as SUB do i need any more license or we will install the CUCM software in that server and select to be SUB ?
rehards
Talaat
CUCMBE as a Backup
The cluster to which you'll join the server needs to have node licenses available.
java
java
164
