Community Member
CUCMBE; UC users not seen for import from CUCM LDAP
I have CUCMBE 7.1 integrated to AD and have successfully sync CUCM users into LDAP from AD. However, Unity Connection doesn't see them to import if I go to TOOLS> IMPORT USERS> and Find End Users in UC. Is there anything else I need to do to import users into Unity Connection from CUCM BE?
THANKS!
1 ACCEPTED SOLUTION
Community Member
Re: CUCMBE; UC users not seen for import from CUCM LDAP
Have you checked to make sure that all of your users in CUCM have a Primary Extension defined under the Directory Number Associations section of the End User page?  You won't be able to import users into CUC until they have a primary extension.
VIP Super Bronze
CUC doesn't pull LDAP users from UCM and the product documentation says that: Integrating Cisco Unity  Connection  with an LDAP Directory
AXL synchronization does but you cannot do LDAP authentication then.
Community Member
It looks like CUCMBE-UC doesn't even have an option for LDAP under SYSTEM SETTINGS>.   Also, under "Help for this page" for the TOOLS> SYNC USERS>  For Find Imported users, it states:
"In a coresident configuration, synchronization happens automatically. There should be no need to manually synchronize users" which leads me to believe that I should automatically see users in my database without doing anything. (I cannot add users manually in UC for CUCMBE).
Community Member
Community Member
Joel,
   Thanks. I had ended up opening a TAC ticket and the primary extension number along with device association was suggested. I knew I was missing something simple, and the documentation didn't mention anything on it.
Thanks!
Community Member
No worries.  Yea you cannot assign the primary extension until you associate the device to the user.  Glad you got it fixed.
1198
