09-14-2009 11:03 AM - edited 03-15-2019 07:44 PM
Was wondering if it is possible to configure CUCME 4.2 / 4.3 with extension mobility username/password using only numeric characters
09-14-2009 11:04 AM
If numeric only is accepted by the CLI, it is possible.
If not, it is not possible.
09-14-2009 11:24 AM
Hi ,
Thanks for your reply.
In callmanager it is possible to enable only numeric login and the alphanumeric characters are disabled.
We are trying to speed up typing in numbers only for the username & password.
So to clarify so that when you type in username letters are disabled and only numbers are active.
Hope this is clear
09-14-2009 11:33 AM
Seems like you tried numeric-only usernames and they do not work.
In CME there is no command to enable that.
CME is not CM.
