CUCME 4.2 Extension mobility
Was wondering if it is possible to configure CUCME 4.2 / 4.3 with extension mobility username/password using only numeric characters
Hall of Fame Super Gold
Re: CUCME 4.2 Extension mobility
If numeric only is accepted by the CLI, it is possible.
If not, it is not possible.
Hi ,
Thanks for your reply.
In callmanager it is possible to enable only numeric login and the alphanumeric characters are disabled.
We are trying to speed up typing in numbers only for the username & password.
So to clarify so that when you type in username letters are disabled and only numbers are active.
Hope this is clear
Seems like you tried numeric-only usernames and they do not work.
In CME there is no command to enable that.
CME is not CM.
134
