06-03-2010 08:29 AM - edited 03-15-2019 11:05 PM
HI,
it's possible to configure CCME ver 8.0 for that internals call to "Standard" (000) and the external call to International (0 00 XX...) work on same time??
Thank's for your help
Solved! Go to Solution.
06-04-2010 11:39 PM
NO, simply you can't.
The best practice is to press '9' before pressing any local/national/international PSTN number. You can use '000' as one of your DN, but you can't dial-out with any number starts with '000' and vice versa. CME creates dial-peers (which you can't see on running config) each time after creating each ephone-dn, so a dial-peer with 'destination-pattern 000' already exists on your CME, when you want to compare it with 'destination-pattern 0T' who should win?
HTH.
Please rate helpful posts!
06-03-2010 12:49 PM
Sorry, what do you mean! Can you clear the question with exact numbering plans and what feature exactly you need?
06-04-2010 01:01 AM
I'll try to explain a little more.
my internal phone numbers are 000 to 499.
the DN 000 is used by a phone
the user must join an international phone number dialed out 0 for 00 and then the country code (eg 33 for France).
The call is redirected to the home and can not leave because the first 3 digits to be dialed is 000.
ALL other call (national and internal CUCME) it's ok..
Is there a possibility of saying run this way change the dial plan?
06-04-2010 11:39 PM
HTH.
06-05-2010 09:59 AM
that's what I thought. thank you for respons.
