Community Member
CUCME 8.6 : PHONE CALLS THROUGH VWIC2-1MFT-T1/E1 AND FAX THROUGH ISDN VIC2- BRI-NT/TE
My configuration is Cisco Unified Communication Express 8.6, I need my normal phone call go out through VWIC2-1MFT-T1/E1 and FAX call go out through ISDN VIC2-BRI-NT/TE, how can I do that ? Thanks for your help.
Best regards,
Ludovic GUYOMARD
Hall of Fame Super Silver
You will need to build corlists to force specific routes.
HTH,
Chris
Community Member
Hi Chris,
my fax are on fxs port, is it possible to apply corlist on FXS port ?
Best regards,
Ludovic GUYOMARD
163
