CUCME and Dialogic softIP SIP
lars.molstad
Hello folks,
I am trying to get a Fax solution based on the Dialogic softIP SIP environment working.
My gateway has a E1 and a SIP-trunk to another gateway for another solution, and I have figured out that I probably will need some CUCME functionality to get this working..
So my question is: Has someone got this working? Dialogic states that softIP SIP is known to work with CUCME.
I have about no experience with SIP so I would be pleased if someone has some config-samples or documents pointing out how to get the softIP working with a Cisco router in some way or another...
L@rs
mchin345
Level 6
Level 6
Use the following guide for softIP SIP
Cisco Fax Server Administration Guide, Release 9.3
http://www.cisco.com/en/US/docs/voice_ip_comm/fax_server/93/93ciscofaxadmin.pdf
