CUCME CFA and CORLIST
Hi all,
We have the following scenario:
CME - Ver 8.0.0 with cor list configured
IP Phone A is configured to be able to call to mobile destination. Tested.
IP Phone B is configured to not be able to call to mobile destination. Tested.
When IP Phone A user configures a call-forward all to a mobile destination and IP Phone B calls to IP Phone A the call-forward does not work. If we change the incoming cor list of phone B to make it able to call to mobile destination, the forward works.
So, is this the expected behavior? Is there any way to configure cor list for forwards in CME?
COR Configuration:
dial-peer cor custom
name FijosNacional
name Moviles
name Num112
name FijosProvincial
name Internas
name 112
name Internacional
dial-peer cor list LlamarProvincial
member FijosProvincial
member Internas
member 112
dial-peer cor list LlamarNacional
member FijosNacional
member Internas
member 112
dial-peer cor list LlamarMoviles
member Moviles
member Internas
member 112
dial-peer cor list LlamarInternacional
member Moviles
member Internas
member 112
member Internacional
dial-peer cor list LlamarInternas
member Internas
member 112
dial-peer cor list LlamarEmergencias
member 112
Mobile dial-peer configuration:
dial-peer voice 300 pots
corlist outgoing LlamarMoviles
description Salida a moviles - 6XXXXXXXX
preference 1
destination-pattern 06........
port 0/1/0
prefix 6
Telephony-service configuration:
telephony-service
authentication credential administrator csicuna
max-ephones 110
max-dn 400
ip source-address 192.168.4.254 port 2000
timeouts ringing 120
system message Instituto de NutriciC3n Animal
url services http://192.168.4.253/voiceview/common/login.do
url authentication http://192.168.4.254/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
user-locale ES load CME-locale-es_ES-Spanish-7.0.1.1.tar
network-locale ES
load 7911 SCCP11.8-5-2SR1S.loads
load 7942 SCCP42.8-5-2SR1S.loads
load ata ATA030204SCCP090202A.zup
time-zone 23
time-format 24
date-format dd-mm-yy
voicemail 800
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
multicast moh 239.10.16.4 port 2010
web admin system name administrator password csicuna
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 0
directory entry 1 0958181600 name Est. Experim. Zaidin
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone A configuration:
ephone-dn  61  dual-line
number 123
pickup-group 23
label Alejandro Morales (ext.123)
name Alejandro Morales
call-forward all 0666778899
call-forward noan 800 timeout 30
corlist incoming LlamarInternacional
corlist outgoing LlamarInternas
mwi sip
ephone B configuration:
ephone-dn  7  dual-line
number 120
name Sala ordenadores
corlist incoming LlamarProvincial
Thanks in advance.
Salud
PD: Sorry for my English
212
