CUCME conference problem
Hi! I'm facing a weird problem - unable to setup the hardware ad-hoc  conference on cucme 7.0.
The only symptom is that when the second  phone number is dialed and the conf soft-button is pressed for the 2nd  time busy tone is received and ip communicator displays "->5801" and  "busy" down on the screen (call status). 5801 is the first of 4  ephone-dns created for hw conference.
When simply dialing this  number the call status is something like "unable to set up a conference"  (russian locale, not the exact text).
When testing I used CIPC  and dialed first the mobile phone through analog lines to phone service  provider (successfully) then
pressed conf button and dialed  external phone number through voip peer (also successfully) and pressed  conf button 2nd time.
The same scenario was tested on local hard  ip phones with the same result, so I don't think the issue is related to  tall-fraud protection mechanisms
or something like that.
The  dspfarm profile is successfully associated:
C2821#sh dspfarm profile
Dspfarm Profile Configuration
Profile ID = 1, Service =  CONFERENCING, Resource ID = 1
Profile Description :
Profile Service Mode :  Non Secure
Profile Admin State : UP
Profile Operation State :  ACTIVE
Application : SCCP   Status : ASSOCIATED
Resource Provider :  FLEX_DSPRM   Status : UP
Number of Resource  Configured : 2
Number of Resource  Available : 2
Codec Configuration
Codec : g711ulaw,  Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw,  Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum  Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8,  Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum  Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum  Packetization Period : 60 , Transcoder: Not Required
The  dsps seem to be used when the conference attempt is made:
while ->5801 busy
is displayed:
C2821#sh dspfarm all
***omitted part***
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    5   23.8.5   UP     1    USED  conf    1      0x3C2       886       886
0    5   23.8.5   UP     1    USED  conf    1      0x3C3       888       883
0    5   23.8.5   UP     N/A  FREE  conf   1      -         -         -
Total number of DSPFARM DSP channel(s) 2
After it has aged out and soft phone  is not on call:
***omitted  part***
What could cause this behaviour?
I'm  almost sure it worked when I was testing the system and I thought it  could be COR-related issue. But I tried to remove corlists from affected
peers  and dns or assign different in and out lists to a block of conference  dns with no success.
Box is cisco2821, sw is  12.4(20)T4 adv. ip services, cucme is 7.0(0), phones firmware is 8-3-3S  and 8-4-2S (doesn't affect the case as I expiriment on CIPC), CIPC  version is 2.1.3.0.
Almost complete config  is in attachment.
Everyone's tags (3)
450
