CUCME Help
Is ther a way to forward unused DN in CUCME to say an announcement?
CUCME Help
Are you asking if CUCME, has the annoucement functionality?
Yosh
HTH Regards, Yosh
CUCME Help
No, just if there is a way to forward unused DN's to a announcement only mailbox in CUE.
The only way I see it is to create an ephone-dn for every unused DN and then call forward all to another DN configured with a announcement only mailbox.
Is there a better way?
CUCME Help
You can create a number expansion that points to the CUE announcement number. Example below
num-exp /^70../ /1000/
Yosh
HTH Regards, Yosh
CUCME Help
Will this work as a final "catch all?"
Let's say I have some numbers in the 70.. range that are being used with specific ephone-dn's. Will they still apply as the more specific pattern and then this num-exp will apply to the the rest, or will this supercede and take over even the valid ephone-dn's?
Does that make sense?
CUCME Help
I'm pretty sure it will supercede. The pattern needs to only match the un-used DNs.
Yosh
HTH Regards, Yosh
CUCME Help
I think it will too, I may have to enter individual unused DN's and forward them to the announcement, I am afraid. Thanks for the assist, Yosh!
CUCME Help
You're welcome Sanjay, below is a link for more information on number expansion.
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/dialpeer/configuration/12-4t/vd-12-4t-book.pdf
Yosh
HTH Regards, Yosh
134
