Community Member
CUCME in SRST v8.1 Port 2000 Phone Not Register on VG
We have CUCM 7.1
We have 2821 Router at remote site running 151-2.T1
The basic config...
telephony-service
srst mode auto-provision none
srst dn line-mode dual
ip source-address 10.10.10.1 port 2000
etc..
I cann't telnet to this router with command: telnet 10.10.10.1 2000
I can on my other routers running v7.1
I see there is a new command in v8.1
   sh telephony-service license
Do I need a license file on this router?
We have Cisco 6921 phones at this site that require v8.1
I also have the standard license envolope from Cisco FL-SRST-25=
Has anyone seen this?
Matt
Re: CUCME in SRST v8.1 Port 2000 Phone Not Register on VG
Here's a base config
telephony-service
max-ephones 30
max-dn 60 preference 0
srst mode auto-provision all
ip source-address
create cnf
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesrst.html#wp1010721
Let me know if that helps. 6921s are supported in SRST 8.1. That shouldn't be an issue.
Community Member
Not work.
I'm told by Cisco Licensing I need a license on the Router.
Does anyone know how that done?
My license I got in the mail says nothing about it.
FL-SRST-25=
Matt
Silver
Matt,
This sounds like it might be related to:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCte08121
At a quick glance it looks like your IOS version might not have the fix for that defect. Can you try the latest T code and see how it goes?
-Jason
322
