CUCME integration with LDAP/Active Directory
Does the CallManager Express 7.x support integration with LDAP/MS-Active Directory ?
Re: CUCME integration with LDAP/Active Directory
No, that's only available on full CUCM
java
if this helps, please rate
java
www.cisco.com/go/pdi
It does not support integration but you can configure directory access with CUCME.
By integration I mean creating CUCME users by syncing with LDAP.
By directory access I mean the ability to search LDAP user records from an IP phone by name and dial associated phone numbers.
You can do this using the CallManager SDK as described in the link below.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/directry.html#wp1044946
Hall of Fame Super Gold
If you're interested in acquiring such a module, contact me at the address present in my profile.
You can try http://www.visualviewmail.com this is a new AD directory but it integrates nicely with CUCME and Exchange 2010.
520
